Ir para o conteúdo principal
TRIO STEALTH G2 9.7 INCH/Model: MST9-21/8GB Internal flash memory
Why is my tablet so hot?
At a certain point, my tablet is so hot. I have to stop playing it for a while. Is there anyway to avoid this problem?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Your storage may be full or you may be using the tablet in too long of periods. You might want to check your storage first. If the storage is full you need to delete some useless applications. There is another case where you might have too many applications running in the background. Close these applications if not in use.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Mei Liang será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Ao todo: 373
