Ir para o conteúdo principal
ATX Mid Towers have the same general build and parts as other mid size computer towers
32 Perguntas Visualizar todos
Pergunta encerrada
Why is my computer making beeps? what do I do?
The computer is making some beeping noise, its not normal
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
The motherboard of your computer is built with somewhat of a warning system. This warning system can sense certain problems with your computer and will beep in different frequencies and durations to let you know what the problem is. There are a variety of problems that can happen, each containing its own code of beeps. When this happens the problems are usually more severe and should be taken care of as soon as possible. The following URL will bring you to a web site to help identify what these beeps mean: https://www.pantz.org/hardware/bios/beep...
Esta resposta foi útil?
Pontuação 0
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 149
