Ir para o conteúdo principal
Released in 2013, this multifunction laptop is a part of the Satellite C50 laptop series. It has a 15.6" display screen and comes with Windows 8.
11 Perguntas Visualizar todos
How do I get my mouse pad to work?
I keep moving my finger across the touchpad, but I can't click on anything. It is not allowing me to move the pointer.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
You could have locked your mouse pad, try turning that off first. You can find this by looking at the keys in the highest row. It will be F4 and when you click it, the computer will tell you if it’s on or off.
If that doesn’t fix it then the mouse pad may be dirty and need to be cleaned. Dust away any dirt with a cleaning duster. Then, take a computer cleaning solution and spray on a cloth. Wipe the cloth across and the touchpad until any stickiness is off.
If these don’t fix your problem, then the mouse pad may need to be replaced.
If you're still confused, then check out the Toshiba Satellite C55D-A5201 Troubleshooting Page.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Andrea Colindres será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 3,630
