Ir para o conteúdo principal
How do I replace my track pad button?
Mouse pad Button is stuck and I need a replacement, donor or otherwise. Please advise.
Esta é uma boa pergunta?
Pontuação 3
Adicionar um comentário
3 respostas
Solução escolhida
A less expensive answer if you want to go that way would be to simply use an external USB mouse. If the button is stuck in the on position you may need to disconnect the trackpad cable to operate properly. Ralph
Esta resposta foi útil?
Pontuação 2
I am using a new answer because I can't leave a URL in comment.
If you do want to replace the upper case here is a source. Ralph
http://cgi.ebay.com/Apple-PowerBook-G4-1...
Pontuação 2
2 comentários:
For the record I tried three times to leave this as a comment but the program would not allow me to leave a "clickable" url. Ralph
por
So it isn't just me! If it happens to everyone I'll mention it on the uservoice
por
You would need to replace the upper case.
Pontuação 1
Adicionar a sua resposta
Jackson Carrie será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 14
Ao todo: 3,526
