Screen Replacement; Tegra Note 7
Does anyone know how to replace the screen on the tegra note 7
I cracked mine. I just don't know how to take the tablet apart.
Esta é uma boa pergunta?
The tablet is held together with clips along the seem in the sides of the tablet. If you plan to open the device, be sure to remove the SD card, Flip Cover (or slot protector), stylus, and SIM card if applicable. To open the device, slide the end of a nail file or other slim object into the seem and work along the edges carefully. Each clip should yield with a click but you have to be careful not to break them.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 29
Ao todo: 3,380
Where you bought the replacement?
It is impossible to get, as you did?
Thank you
por diegoglatzel Compartilhar
