Ir para o conteúdo principal
A segunda geração do iPad com modelos Wi-Fi, GSM e CDMA. Alguns modelos foram atualizados antes do iPad 3. O reparo é difícil e requer procedimentos de calor e separação.
730 Perguntas Visualizar todos
Pergunta encerrada
Replacing LCD on iPad 2
Hi I'm replacing LCD on my iPad 2 and it has a small anti dust foam gasket running all around it, which apparently does not come fitted to new LCD, does anyone know where I can buy one of these gaskets from? I have found some on Internet but all are wholesale only :(
Cheers,
Neil
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
The short answer is: you can skip that part.
But why did you need to change the screen to start with? Unless physically damaged, those LCD rarely fail. It is usually the LCD cable that needs reseating or replacing.
Esta resposta foi útil?
Pontuação 1
hi rottenpunk,
the dust gasket u can buy on etradesupply.
i can not give u a link, cause the system will mark it at spam- this already happened.
etradesupply has a warehouse in the US.
i am in switzerland and order from the warehouse in china.
it's the best dust gasket i ever saw, cause it's comeing on a template.
just place the gasket over the lcd and push a little bit and take it off and thats it.
Pontuação 0
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 177
