also have the error 53
I also have the error 53
My screen was never replaced- I DID replaced the flex cable-
Phone was dropped in water but no signs of corrosion- even the liquid sensors did not change color-
After the phone was dropped- i let the phone "dry out" I did not remover the battery BUT the phone worked fine for over a month with no lasting effects of the water-
The issue started when I "erased all content" through the phone- it locked up so I figured I would just update it-
This is where error 53 happened- it was bout 5-% done when the error popped up---
Nothing in the phone was corroded – I changed the flex cable because I read that was a common issue- but I didn’t fix mine…
Esta é uma boa pergunta?
