Ir para o conteúdo principal
Liberado em abril de 2010 com as opções de processador i5 de 2,4, 2,53 GHz Core ou i7 de 2,66, 2,8 GHz Core
590 Perguntas Visualizar todos
My MacBook wont turn on after battery damage
Hi, after 10 months of not using my macbook I decided to use it again and charge it, the next day after I charge it, the battery got swollen very bad it even knocked the touch pad out of its place, I took off the back cover and removed the battery, then I connected the power adaptor but the macbook didnt turn on, at 1st the light on the power adaptor was on but after a few tries it went off and never came back, now whenever I connect the power adaptor the only thing that turns on is the "battery indicator thingie" light, it flashes a few times when I press the button...
please help
Thank you
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
Unplug trashed battery. Hold power button down. Keep holding power button down. Then plug charger in, with power button held down. Does it turn on?
Esta resposta foi útil?
Pontuação 1
2 comentários:
No, it didnt, the only difference is battery indicator didnt lit while doing what you suggested
por
Measure voltage on PPBUS_G3H, PP3V42_G3H, PP5V_S5 and PP5V_S3 on your logic board. Red probe on point where voltage shows up, black probe on ground.
Then switch multimeter to diode mode. Red probe on ground, and black probe on the following points; measure SMBUS data line ends of R5280 & R5281 WITHOUT battery or charger plugged in, using diode Should be 0.435-0.461 on a non-&&^&@@ up board.
You will need a multimeter, schematic, and boardview for your specific logic board model number to begin this journey. If you are willing to follow along, I can help you troubleshoot the problem, learn something, and save a lot of money. If this seems like a nightmare, give up and buy a new machine.
por
Adicionar a sua resposta
IzeQ será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 4
Duração total: 162
