Ir para o conteúdo principal
Use this repair guide to fix faulty parts in the Fujifilm FinePix S2980.
12 Perguntas Visualizar todos
Why is my camera not turing on?
I keep using the power switch and the camera won't turn on. The screen is black and not making any sounds, what should I do?
Esta é uma boa pergunta?
Pontuação 6
Adicionar um comentário
3 respostas
Pergunta mais útil
Hi John,
There are a couple things that might be wrong. The first thing that I suggest doing is replacing the batteries. If you do that and the camera still does not turn on, you may have to replace the power switch. Check here for more information.
Hope this helps!
Esta resposta foi útil?
Pontuação 1
The lense won't extend. And tells me turn back on.
Pontuação 0
I had a battery leak in the battery compartment how can i repair my s2500hd camera?
Pontuação 0
Adicionar a sua resposta
John Kemmitt será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 3
Últimos 30 dias: 5
Ao todo: 1,961
