Ir para o conteúdo principal
O iPhone 5s da Apple foi anunciado em 10 de setembro de 2013. O reparo deste dispositivo é semelhante ao de modelos anteriores e requer chaves e ferramentas de abertura. Disponível como GSM ou CDMA / 16, 32 ou 64 GB / nas cores prata, dourado e cinza espacial.
Camera flash not working
My Iphone 5s Camera flash doesnt work, its supposed to have two leds, the yellow and the white, the white doesnt work so i press the flashlight icon in control center and it gets highlighted as working but nothing happens, when i switch to video mode it doesnt light up, i notice the LED or bulb doesnt work because when I take a picture with flash ON the yellow light flashes but theres no flash on pictures, so Its not a software problem, please tell me how to fix this problem and the replacement i need to buy, thank you.
Esta é uma boa pergunta?
Pontuação 10
3 comentários
my device camera as well as flash not working . I there any way to fix it
por
it supposed to be yellow and white flash but my iphone 5s flash is just white which still works
por
My flash went out as well how can I solve this problem
por
Adicionar um comentário
6 respostas
Solução escolhida
You need to buy a power volume flex as the led light is located on that
Esta resposta foi útil?
Pontuação 3
1 comentário:
This was the solution to my problem thank you very much!
por
I am also facing this Problem. My volume down button is also not working.. First the volume button fails then Flash of the camera. Amber led working but white one is not!!
Pontuação 1
5 comentários:
Its the power volume flex, that is involved in volume has the led from flash lock button etc, this piece is cheap and replaced in 15 min!! Good luck!!
por
was it safe? I mean repairing? cause I am afraid that something other will not mess up
por
Well, this piece involves a lot of the phones features but just follow the video and i guess you'll be fine, but if youre not the the "i'll repair it myself person look for someone to fix it for you, obviously experienced.
por
can u post a video?
por
Sania nadeem,
Finally I fixed this problem to replace the (power volume and flash light) single flex...
por
Here you can get a power volume flex http://www.iboxfix.com/flex-ribbon-c-164...
Pontuação 0
same to sania
Pontuação 0
my iphone 6 flashlight is working on Video and flashlight but When I taking a picture with flash, white led is working but Amber led is not working.. because of that picture with flash is being dark !
Do you have any idea What is the solution ?
thank you
Pontuação 0
i;gt9 6tp/y8 g;p.gilbuj,gbulihilihh
Pontuação 0
Adicionar a sua resposta
Alex será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 21
Ao todo: 24,697
