Why won't my camera turn on?
When I press the power button, nothing happens.
Esta é uma boa pergunta?
The simplest reason for this problem is an issue with the battery and charging system. Make sure you are using the proper USB charger and cord and they are not malfunctioning or damaged. If everything is working normally there may be an issue with your battery, which you can replace by opening the battery compartment.
Esta resposta foi útil?
I have a Samsung St77 and when I charge it with the battery inside using a usb it just blinks red light and it means that it has an error, how do I fix this?
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 36
Ao todo: 1,019
1 comentário
Mine fell down and the lens never eject
por S`busiso mqapheli
