Ir para o conteúdo principal
Improved second generation Google-branded tablet with a 7" screen.
98 Perguntas Visualizar todos
Pergunta encerrada
Will 2nd Gen Nexus 7 power on w/o back case?
Let me explain: I have repaired many First Generation Nexus 7 tablets, and they will power on without the back casing intact. I do this just to make sure everything is in order and working properly before I put it on, saving me the trouble of prying it off again. However, I just replaced the screen on my personal tablet which is the second generation (2013) model, and I cannot get it to power on with the back casing off. I noticed that there are little "connectors" on the back plate that would make contact with the frame when put together. Is this what keeps it from powering on when the back case is off? For those who are wondering why I don't just put the back case on and see if it works, the reason is that the Chinese based eBay seller who sold me the frame/ screen combo did not include the volume/power flex cable, so all I had was an old 2012 model flex cable that will not fit inside the case properly (but it does fit in the ribbon slot). I am sorry if this doesn't make any sense. It is really hard to explain.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
I have a nexus 7 2nd gen and it will power on without the back case. The power buttons dont work great so i use a power to volume button app as a workaround. Hope this helps
Esta resposta foi útil?
Pontuação 1
1 comentário:
This was helpful, thanks so much. I finally have it working again!
por
yes it will power on without the baCK ON IF HAVIGN THAT MUCH TROUBLE WITHT HE BUTTONS REPLACES THE BUTTOS OR THE POWER AND VOLUME CABLE
Update
btw the raise wifi atennas are what contact the back cuase the backign has the ateena surface for your wifi or celular or for wireless charging
Pontuação 0
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 158
