How do I replace the charging port?
How to replace the charging port
Esta é uma boa pergunta?
You can find charging ports all over the internet. The port is surface mounted...If you know how to solder SMD components and can find a teardown you should be good to go.
Use: "Motorola RAZR Maxx HD Charging Port" as your search criteria on google.
Esta resposta foi útil?
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 3
Duração total: 701
