Ir para o conteúdo principal
A corded phone with companion cordless phone developed by Uniden.
8 Perguntas Visualizar todos
There is noise/static on the line
When I go to call someone i keep hearing static on the line.
Esta é uma boa pergunta?
Pontuação 1
1 comentário
Adicionar um comentário
2 respostas
Solução escolhida
Check for interference from appliances (microwave ovens, TV's etc.). or wireless devices (baby monitors, WiFi equipment, etc.). Move the handset or base away from the interference source.
If you use a telecoil hearing aid, turn on T-coil mode in the Handset Setup menu. T-coil mode shortens talk time, so keep your battery fully charged.
Check Troubleshooting page Uniden D1688 Troubleshooting Repair
Esta resposta foi útil?
Pontuação 1
1 comentário:
Randall the troubleshooting guide is just a placeholder (has nothing).
por
Pergunta mais útil
If all of your handsets have static then its likely your phone line has a problem.
You should call your phone service provider to check the lighting arrestors and your phone lines grounding. Often the arrestors wear-out and your grounding rod and/or power line ground connection is not good. In some cases the grounding is though your waterline (copper line). Corrosion can effect the effectiveness of the ground.
Pontuação 1
Adicionar a sua resposta
Zachary será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 2,645
