back breaklights dont work,all other lights do. not a fuse or bulb.
need wiring diagram or hints to the problem.
Esta é uma boa pergunta?
The brake switch is located behind the brake pedal attached to the push rod..It could be faulty or stuck. Because its an important component I would replace it even if you find it's just stuck.
The Diagram is on this page...
Esta resposta foi útil?
Can see the diagram third brake light works nothing on the rear.
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 13
Duração total: 550
Would the thrid brake light stll work with the brake switch blown?
por Roger Blankenship
