internal display not working
i got a free iMac from from work and the display only works sometimes , as of late not at all .but the display out works every time .and i can't determin if its the lcd or its the gpu. the gpu does run a lil hot i have to turn the fan up or it gets to like 90 c .with fan turned up the card is around 55 to 60 c at idle normally . and i got 3 diagnostic led's on the board on 4th led is off . how do i go about testing the lcd to determine if its the bad part or gpu.
Esta é uma boa pergunta?
travis, your GPU also drives the external monitor. Since it works at all times, you can rule that out.
por oldturkey03
