Ir para o conteúdo principal
The Kenwood Receiver model KR-V7070 is an audio/video receiver produced by Kenwood Corporation, a Japanese company that designs, develops, and markets car audio systems, hi-fi home and personal audio systems, professional two-way radio communications equipment, and amateur radio (“ham”) equipment.
13 Perguntas Visualizar todos
Pergunta encerrada
Volume indicator indicates bacwards
Volume indicator starts at 60 (no volume) and counts backwards to 1 (full volume) What do I do to fix the problem? Or is there some good reason as to why the volume is indicated this way?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
From the units I've seen, home receivers are just set up that way. I'm sure someone will have a better answer after me. If you look carefully, it will probably be a negative 60, rather than positive. That's the experience I've had, anyway.
Basically, each decibal is a ten-fold increase in sound. If no sound was labeled as zero, ten times that would still be zero. So the loudest volume is used as a reference instead.
Esta resposta foi útil?
Pontuação 1
Try reversing the lead in wires.
Pontuação 0
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 1,700
