How can I clean the fan?
Every now and then my computer will randomly shut off, usually when I have been using it for several hours. I think it is because there is dust in the fan?
Esta é uma boa pergunta?
Hi Jennifer,
Have you noticed any temperature problems? It's possible your laptop is overheating. Does it start to feel more hot than it should after a while?
Esta resposta foi útil?
If you would like to clean the fan you can remove the back panel using this guide: Substituição do painel traseiro do Asus VivoBook Q200E-BSI3T08 and then you can clean the fan using either compressed air or a small, soft brush.
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 15
Ao todo: 571
