Sensor Temperature not Working?
Seems my sensor temperature is not working.
Can I repair it?
When I turn on my MacBook Air the fan is running all the time. I made Apple recommended procedures for reset SMC and PRAM and no success.
I opened the case and the fan is running all time, since I turn it on. Checking the RPM for the fan in a software it appears as 0 RPM.
Thanks for any help.
Update
Screenshot. Fan appear 0 RPM, but it's running all the time at full speed (noise sound)
Update
Ok. I'm back after the tests!
1) Run the EFI test for the first time. FAILED the test:
Fan - Exaust (test 1) - Quick Motor Test
ERROR - Motor is spinning slower than it should.
- TEST FAILED -
2) Run the same EFI test again and than DON'T FAILED. It PASSED!
3) Run the OS test. Everything PASSED!
During all tests the FAN is running in a noise mode.
You can check the screenshots in that link:
https://dl.dropboxusercontent.com/u/1237...
Any Help???
Thanks.
Esta é uma boa pergunta?
2 comentários
Made a Apple Hardware Test and got the error: 4MOT / 4 / 40000002: Exaust -0
But as I said, the fan is running.
por Leonardo
Replace the fan.
por zzz
