Ir para o conteúdo principal
Um smartphone HTC baseado em Android, lançado inicialmente em 2011. (Também conhecido como HTC Sensation 4G.)
Power button broken, doesn't respond.
As the title says, my power button refuses to work. As a work around I installed an app that lets me use the volume buttons to take the phone out of standby.
I still need to fix the power button though, without it I can't flash a new ROM.
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
first of all make sure the button itself is corrupted, in some cases the ribbon cable of the button has just came out and you can fix it by putting it back there.
it's shown in replacing the screen/digitizer tutorial, just unmount the back cover (which is held down by screws) then detach the top board (it has a single screw.) then you'll see the power button ribbon cable and the power button itself (it's held down by a tiny flexible black plastic, just pull that out off the main chassis).
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
q547 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 9
Ao todo: 279
