Ir para o conteúdo principal
A widescreen 15.4" notebook computer by Compaq released May 2006.
computer doesn't start up
It wont start up. Only see a blinking cursor on a black screen. By pressing F10 while booting up I enter the setup. Here I see for the diagnose the options for selftest harddrive. Everything seems ok. I try to reinstall the windows xp by cd. The cd starts up but then the computer says there is no harddrive. What can go wrong?
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Pergunta mais útil
De Cuyper, sounds like a bad hard drive to me. Try to see if the hard drive shows up in the BIOS. Make sure it is properly connected. Most likely so you will need a new hard drive.
Esta resposta foi útil?
Pontuação 2
1 comentário:
In the bios I can check if there should be a problem with my HD. This seems to be ok. But when trying to install the windows XP the computer sais there is no HD. I connected the hd extern and I can see the HD is ok.
por
Adicionar a sua resposta
De Cuyper será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 8
Ao todo: 459
