Ir para o conteúdo principal
A portable e-book reader developed by Amazon. Repair is straightforward and requires only prying tools and screwdrivers.
Can the USB socket be replaced without replacing the motherboard?
Esta é uma boa pergunta?
Pontuação 7
2 comentários
This is for the kindle paperwhite.
por
I can’t recharge the battery .The yellowflashes intermittentantly as I wobble the recharging cord seemingly there is a connection problem.
What do I have to do to restore the charging capacity.?
Have tried several recharger cords.
Your advice would be welcome.
Thankyou
Mairin Campbell
por
Adicionar um comentário
1 resposta
Solução escolhida
The USB socket is soldered to the motherboard, so it can not be easily replaced without replacing the motherboard. In theory the socket could be replaced with some careful soldering work if you could get your hands on a replacement socket. For someone experienced with replacing small components on circuit boards I'm sure it would be possible, but if you are a beginner with this sort of thing you may do more damage to the circuit board by overheating it. Look closely at the photos in this guide before deciding to try this repair.
Esta resposta foi útil?
Pontuação 8
Adicionar a sua resposta
Tom será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Ao todo: 1,877
