Ir para o conteúdo principal
Floor lamps are lights that sit on the floor. They are not table lamps, which are designed to sit on tables. Floor lamps are usually taller than table lamps.
19 Perguntas Visualizar todos
shorten heigth of poles
have a halogen floor lamp. someone shortened it now i need to add pole back in for height.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
You should be able to get replacement pieces for the pole (depending on how thick the pole is or if there are any decorative aspects) from any home improvement store. Home Depot, Lowe's, Rona. You will have to check to see if you have enough power cord available for the extension though. Fixing something like this is not for the faint of heart so if you are unsure ask someone in the lighting dept on tools you will need etc.
Hope this helps
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
shermoonlight62 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 1,159
