Ir para o conteúdo principal
7.9 inch display / Model A1432 / Available in black or white / Announced October 23rd, 2012 / 16, 32, or 64 GB capacity
LCD - Backlight missing some illumination
Just replaced the digitizer and on re-assembly I've noticed the bottom edge of my ipad has four dark patches. Looks like some of the backlighting LED's are not working? Could it be a single damaged filter connecting the LCD connector? Looks like there are 6 LED drive connections off the connector, so just wondering if I have blown a filter?
Cheers,
Matt
Esta é uma boa pergunta?
Pontuação -1
5 comentários:
Matt, Can you post a picture.
por
Any ideas guys??
por
help?? Please..
por
Hey Matt--looks like you solved this, congratulations! You want to update this question to show us which component was damaged?
por
Adicionar um comentário
1 resposta
I guess the only way to really know is too try a different LCD. The LCDs are pretty fragile. Could also be connector damage, but try a different LCD first then go from there.
Esta resposta foi útil?
Pontuação 0
2 comentários:
It was the filter - one of the 6 was o/c, therefore losing a string of Led's.
por
http://www.cyberdocllc.com/wp-content/up... Replaced one of the 6 filters (labelled as Resistors) as shown on this photo in the green box. These 6 Filters connect to the LED Strings in the LCD, so if one goes down you lose a whole string! :-)
por
Adicionar a sua resposta
matt74 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 14
Ao todo: 191
