Ir para o conteúdo principal
The April 2014 update of Apple's 13" MacBook Air features refreshed dual-core i5 and i7 processors, plus slightly increased battery performance.
313 Perguntas Visualizar todos
Pergunta encerrada
Backlight Non-Functioning after Water Spill
I'm trying to fix a MacBook Air 6,2 (13", Early 2014). The previous owner spilled water on it, but immediately took it to a repair shop, where it was disassembled and dried. As a result, the laptop doesn't appear to have any corrosion, and everything works but the backlight. The LCD functions, so I can use the laptop as normal if I use a flashlight or headlamp to shine light on the screen.
I've done a bit of research, and it seems like this is pretty common after a water spill and happens because of a blown fuse which can be replaced (this seems to be the most successful thread).
I have access to an electrical engineering lab (and EE friends), so I have all the tools I need to test and repair the MacBook.
Can someone tell me which componenets I need to test with a multimeter in order to diagnose which one is the problem? Here are some pictures of the logic board:
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
Highly likely the backlight driver IC has fried and will need replacing.
Esta resposta foi útil?
Pontuação 0
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 266
