Ir para o conteúdo principal
The Asus X200MA is a portable touchscreen laptop with an 11.6" display. This device was manufactured in 2014 and is also identified as Asus X200MA-RCLT07.
37 Perguntas Visualizar todos
Why won't my screen turn on?
My laptop starts and I can hear it running but my screen stays black.
Esta é uma boa pergunta?
Pontuação 5
1 comentário
I have the same problem so i plugged in a external moniter and it works so it might rule out the mother board. also while on external moniter i noticed the mouse and touch screen on the laptop work
por
Adicionar um comentário
3 respostas
Solução escolhida
This is probably a symptom of a broken screen, it may also be due to a loose connection or issues with your motherboard. Refer our troubleshooting guide for more help on this issue.
Asus X200MA Troubleshooting
Esta resposta foi útil?
Pontuação 0
1 comentário:
There's actually no "guide" in your link above. It just stated the cause of the problem but didn't give the troubleshooting steps to be done. I badly need to fix it. More help pls?
por
Pergunta mais útil
Also, check the battery, it may not be charged. You might just need to plug it in!
Pontuação 2
Check RAM
Pontuação 0
Adicionar a sua resposta
Luca será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 3,247
