Ir para o conteúdo principal
A video gaming headset with a detachable microphone and an optional Mixamp Pro to balance game and voice audio. Compatible with Xbox 1, Xbox 360, Playstation 4, Playstation 3, and PC. The "Gen 2" A40 headsets were released between 2014 and 2015.
6 Perguntas Visualizar todos
Is your sound volume/quality low?
When I turn the volume all the way up, I recognize that the speakers were not providing their full potential volume. The sound coming out of the speakers does get louder, however it still sounds as if you were far away from the speakers.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Sound problem is most likely linked with issues in the cables. Here are a couple of things you can do:
1. Make sure all your cables are plugged in securely including the microphone and MixAmp.
2. Try plugging your headset into a different audio source and see if the problem still exists. You can try it with an mp3 player or a stereo.
3. Replace the Quick Disconnect cable that you are currently using with another provided along with the headset.
Hope that helps!
Esta resposta foi útil?
Pontuação 0
if you have 2 applications opened using the headset, one wont be as loud. I was Skyping someone and had a YouTube video playing and when i muted Skype the video got louder.
Pontuação 0
Adicionar a sua resposta
Josue será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 13
Últimos 30 dias: 81
Duração total: 42,198
