Ir para o conteúdo principal
Um videogame de tv fabricado pela Sony Computer Entertainment, também conhecido como PS4. Primeiramente anunciado em 20 de fevereiro de 2013 e lançado em 15 de novembro de 2013.
1696 Perguntas Visualizar todos
Pergunta encerrada
Red light Peeps THREE times
Hey my ps4 recently started to turn off I know that it has overheated and I gave it time to cool down for TWO days I'm wondering if I should just go get it fix it has been over a week and it still does the same till this day
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
If your PS4 overheats at all then it needs to be repaired. If you let it cool down for 2 days and it still does the same thing then you definitely have something going on that needs to be repaired.
If you haven't already you may want to try giving it a good cleaning by blowing out all the vents and making sure there isn't a whole bunch of dirt and grime in the air vents. Also make sure it's in a place where it gets plenty of ventilation. If you want to experiment with it a little you could get a fan and make the fan blow on it to see if that gets it to work.
Most likely you will need to have this repaired.
I hope this helps...good luck!
Esta resposta foi útil?
Pontuação 0
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 84
