Ir para o conteúdo principal
O iPhone 5s da Apple foi anunciado em 10 de setembro de 2013. O reparo deste dispositivo é semelhante ao de modelos anteriores e requer chaves e ferramentas de abertura. Disponível como GSM ou CDMA / 16, 32 ou 64 GB / nas cores prata, dourado e cinza espacial.
3530 Perguntas Visualizar todos
Why isnt my iPhone turning on?
I took my front screen of my iphone 5s off to replace it, after i replaced the screen and put everything back together it would not charge and would not turn on, what can be the problem?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
5 respostas
Solução escolhida
Remove the new screen.
Disconnect the battery. DO NOT remove it.
Press and hold power button for ~15 seconds.
Re-connect the battery.
Re-install the new screen, make sure it is properly seated. DO NOT yet re-install the small shield covering the screen connectors.
Try to restart your phone, and if needed charge it for 20 minutes first to make sure the battery is holding a charge.
If you still get nothing, repeat the above BUT install the old original screen back, in case you still have it and it is still working. If this time the phone restarts, you were trying to install a defective screen, get a new one.
If still nothing happens, let us know to help you figure out the next possible step.
Notes:
A/ As an additional measure, before re-installing the screen the first time, you can clean the screen connectors on the board using a cotton swab or a very soft brush dipped in 90%+ isopropyl alcohol.
B/ Use this guide, step 11, to place black the screws of the shield exactly where they should be. Do not mix them up or your risk permanently damaging your iPhone.
Esta resposta foi útil?
Pontuação 1
Pergunta mais útil
Maybe it's caused by short circuit or somewhere being improperly assembled, try to power on your iPhone 5s while charging it.
Pontuação 1
The LCD resulution 1136 x 640 pixels by 326 ppi are the same from the digitizers but the flex cables are difference.
You must need a iPhone 5s screen for the digitizer. Be careful with the touch ID cable. Once broken you never are able to replace the touch ID part, because the Touch ID i encrypted part to the logicboard.
Succes !
Pontuação 0
My iPhone 5s isn't turning on u can see the apple when it first turns on but then it goes black and does it again it's been doing this for 2 hours
Pontuação 0
1 comentário:
Have you tried restoring it with iTunes?
por
Does iTunes recognize it?
Pontuação 0
Adicionar a sua resposta
Tyler será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 141
