Ir para o conteúdo principal
Repair guides for smartphones manufactured by LG that use the Android operating system (OS).
2552 Perguntas Visualizar todos
How to replace Optimus L70 digitizer?
Anyone know how long it takes to replace the digitizer? looks like all you need to do is disconnect the connector from the back of the board, then separate the front from the glue. looks like 10 mins. probably is one hour.
Esta é uma boa pergunta?
Pontuação 3
Adicionar um comentário
1 resposta
Solução escolhida
The way to replace it is to take off the motherboards and then replace the screen by heating up the glue around the screen and pry it off. put on the new screen and reassemble. I find it to be the easiest phone to fix
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
dan z será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 688
