Ir para o conteúdo principal
The second generation HTC One—dubbed the HTC One (M8)—features a dual flash and the new Sense 6 UI, and was released March 25, 2014.
202 Perguntas Visualizar todos
How do I replace rear camera on HTC One M8?
When any camera app is launched, the phone makes a buzzing sound and the image vibrates. It's as if there was a mechanical zoom or image stabilizer system that had become possessed. Without warranty, I figure I would attempt a DIY repair.
Esta é uma boa pergunta?
Pontuação 6
3 comentários
Have you found a solution to this problem. I have it as well
por
Camera modules are cheap enough on eBay. I just haven't built up the nerve to open up the phone.
por
Dear Victor,
Have you ever replaced the camera? Didn't you have "Duo Camera blocked" message always appearing problem? If so, how did you solve it?
Thank you in advance.
Best regards
por
Adicionar um comentário
2 respostas
Pergunta mais útil
You can do as HTC One M8 teardown from ifixit.
You also can see that HTC One M8 daughterboard replacement video. After removing the daughterboard,you can remove the rear camera easily.
Esta resposta foi útil?
Pontuação 1
HTC One M8 camera focus vibration please solution
Pontuação 0
2 comentários:
I ended up calling HTC and they sent out a replacement in two days. Great service especially considering I got the phone second hand through bartering and not purchasing.
por
was your phone under wareanty?
por
Adicionar a sua resposta
Victor L será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 8
Duração total: 7,478
