Ir para o conteúdo principal
Model A1312 / Mid 2010 / 3.2 GHz Core i3 or 2.8 & 3.6 GHz Core i5 or 2.93 GHz Core i7, ID iMac11,3
replace optical bay with 9.5mm HDD enclosure?
Hey guys,
I'm wondering if it's possible to take out the optical drive on my new i7 iMac and add an SSD boot drive using the 9.5mm HDD enclosure.
any tips appreciated. If the iMac actually has the same optical drive specs as Apple's laptops, this should be possible.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
I see no problem with it except possible warranty voiding. But it can always be removed for service.
Esta resposta foi útil?
Pontuação 2
3 comentários:
So I suppose the question is will the 9.5mm enclosure fit into the 27" iMac? iFixit doesn't list the iMac as compatible, but that might just be an oversight.
por
I just went through the iFixit teardown and it's actually a 12.7 mm bay, so I'd just use the 12.7 mm SATA Optical Bay SATA Hard Drive Enclosure. Mmm.. good! Am looking forward to using SSD as a boot drive.
por
Adicionar a sua resposta
earthvital será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Ao todo: 1,849
