Ir para o conteúdo principal
The fourth iteration of the popular 7" Galaxy Tab line of Samsung tablets.
How do you get the back cover off?
I would like to remove the back cover do you guys have any instructions on how to accomplish this
Esta é uma boa pergunta?
Pontuação 11
Adicionar um comentário
3 respostas
Solução escolhida
On the 10" version, you use a plastic pry tool between the back cover/bezel. They can be a bit still at first. But once you get going, the leverage from pulling it off should help
Esta resposta foi útil?
Pontuação 3
Charles, I posted instructions and the tool used to remove the back cover on your Galaxy Tab. Check the attached links,instruction and guide and plastic pry tool, Good luck.
Samsung Galaxy Tab 4 7.0 Back Panel Replacement
iFixit Opening Tool
Imagem de Plastic tools designed to get you in the tightest cracks, without damaging your treasured devices.
Produto
iFixit Opening Tool
Pontuação 1
Pry it off with a knife
Pontuação 0
2 comentários:
Did it actually work?
por
Is there Other things that is useful?
por
Adicionar a sua resposta
Charles será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 11
Ao todo: 32,895
