Ir para o conteúdo principal
The Nintendo GameCube Controller DOL-003. Released November 2001, compatible with Nintendo GameCube, Nintendo Wii, Nintendo Wii U, and Nintendo Switch. Repair for this device is straightforward and requires only common tools.
46 Perguntas Visualizar todos
Where to buy Circuit Board replacement
I have two controllers that have somewhat broken circuit boards and was wondering if there is anywhere to buy just a circuit board or a way to fix them.
The problem is that either the analog stick or the control stick is very lose and is constantly tilted in a certain direction from over use and abuse. I tried disassembling and cleaning but that doesn't help as the stick the the plastic nubs attach to on the circuit board are the actual problem as they are lose. also I've tried just using other circuit boards but the colour of the plug on the end isn't the same as my orange or purple controllers and i was wondering where i would find the same colours or how to fix mine.
thanks for any help
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
circuit boards for the nintendo controllers are very hard to come by. Being that the game cube was not made for excessive online gaming and any competitive play, they will not produce a circuit board. the best option you have is to look at (gamestop, dic replay, play it again sports, & craigslist) to see if they have a new controller for you to purchase
Esta resposta foi útil?
Pontuação 0
1 comentário:
found a new controller from a store for only 10$ should be easier than trying to replace the circuit board
https://www.google.com/shopping/product/...
por
Adicionar a sua resposta
sean será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Duração total: 2,513
