How can I attach to the charger circuit to add QI charging?
I want to add a QI receiver into my phone however I am having trouble working out where on the Mother board I can attach to.
Does anyone know either where I could attach, or how to identify the charger pins. (i.e. poking random places with a multi-meter on some setting.)
Esta é uma boa pergunta?
Pontuação
0
To answer my own question...
After you remove the motherboard from your Xperia Z there are a set of connector pads on the bottom left. These are where the Mobo connects to the Xperia's charge dock pins and as a result are the perfect place to attach for QI charging.
I was able to successfully wire the connection using foil strips running left then down and up around the battery.
por Nick
