Transmission will only work in low & reverse?
88' gmc, 700r4 transmission won't shift from low to drive.fluid is good. Reverse works. Any ideas?
Esta é uma boa pergunta?
My truck did this also. It cost me $385 to learn that it was a fusible link in the steering column. The tranny shop ran a jumper wire/with an inline fuse to correct this problem. It is good to get a diagnostic test done prior to doing any repairs, recommend the purchase of a personal code reader (it will pay for itself quickly)!!!
Esta resposta foi útil?
Often times the filter will need replacing.
Últimas 24 horas: 4
Últimos 7 dias: 6
Últimos 30 dias: 25
Ao todo: 1,074
