Ir para o conteúdo principal
Fix that arm clock using one of our handy guides!
20 Perguntas Visualizar todos
New battery for SkyCaddie GPS Watch?
I am trying to change the battery on my Skycaddie GPS watch. Can anybody assist with the model / serial number of this battery? and where I can find it on the internet. The only other batteries I find are related to handheld GPS devices and not the Skycaddie watch.
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
4 respostas
Pergunta mais útil
I was able to replace my battery with battery found on ebay. 3.7V 300mAh Rechargeable Lipo Battery Pack PCM 602030 High Rate for MP3 MP4 . You must cut connect off old battery and solder on to new battery. Watch working great. My recommendation is you measure the physical dimensions of your watch battery to make sure same as this battery. Mine was, easy replacement.
Esta resposta foi útil?
Pontuação 1
1 comentário:
Where did you purchase this battery?
por
I have a Skycaddie sport watch.
Battery has always been bad....I decided to change it out.
Battery:
1.11wh CE UL
new 452530 3.7v
300mah 131009
I am having no luck finding the replacement...I would appreciate any help given.
Thx,
Ross
Pontuação 0
1 comentário:
Did you ever find the battery for your Sky Caddie 360? I need one for mine if you could pass on the information. Battery:
1.11wh CE UL
new 452530 3.7v
300mah 131009 < our number (140625) all else was the same
Thanks Jerry
por
where did you get this battery from?
Pontuação 0
1 comentário:
it came with the watch
por
Called SkyCaddie people regarding the battery problem, their response to the problem was a new charger cable. uhh..no help...BatteriesRus store quoted $200.00 replacement cost. Tossing the SkyCaddie and moving to Garmin.
Pontuação 0
Adicionar a sua resposta
Kincaid será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 3
Últimos 30 dias: 15
Ao todo: 1,848
