Ir para o conteúdo principal
iPhone de quarta geração lançado em 2010. O reparo é simples, mas o vidro frontal e o LCD devem ser substituídos juntos, como uma unidade. GSM / 8, 16 ou 32 GB de capacidade / Modelo A1332 / Preto e Branco.
2375 Perguntas Visualizar todos
Pergunta encerrada
Why does my speaker doesn't work?
my iphone 4 speaker is not working I already tested the sound chip by doing a bridge between the two pins in the dock and an aux cable connected to a random speaker and by testing the speaker of the iphone by doing a bridge between it and an ipod/or a computer and it did work.
I also did a bridge between the iphone and its speaker but with no results
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hello Marco, it sounds like your device has a faulty charge port assembly which is causing your problem. That or your headphone jack flex cable is damaged and causing the speaker to not function. Just to be sure, I would replace both cables and check your work.
Heres some guides to help
Headphone jack flex
Charge port assembly
Hope this helps, Good luck mate!
Cheers!
Imagem de iPhone 4 Dock Connector
Guia
iPhone 4 Dock Connector Replacement
Nível de dificuldade:
Difícil
45 minutes - 1 hour
Imagem de iPhone 4 Headphone Jack & Volume Control Cable
Guia
iPhone 4 Headphone Jack & Volume Control Cable Replacement
Difícil
Esta resposta foi útil?
Pontuação 1
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 65
