Ir para o conteúdo principal
Late 2011 model, A1278 / 2.4 GHz i5 or 2.8 GHz i7 processor.
591 Perguntas Visualizar todos
iSight green light always on / Camera not working
As soon as the laptop is turned on, the green light comes on and stays on.
I've:
- Unplugged the battery and camera cable at the logic board
- Reset SMC/PRAM
- Tried a different program besides Skype.
The camera will not show up (microphone works fine).
Before I take the drastic measure of replacing this difficult to replace camera, is there anything left to try? :)
Esta é uma boa pergunta?
Pontuação 2
1 comentário:
when you reset the pram did u hold the keys till it chimes 3-4 times? sometimes just once isn't enough
por
Adicionar um comentário
2 respostas
Having the exact same problem.
Did you find a solution?
Esta resposta foi útil?
Pontuação 0
1 comentário:
No, unfortunately. I'm guessing it was a hardware error but replacing that camera in a unibody model is a pain
por
I have the same exact problem since September 20 .
Someone found a solution?
Pontuação 0
Adicionar a sua resposta
KRepair será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 5
Duração total: 7,412
