Ir para o conteúdo principal
Pergunta encerrada
iPhone only powers on when plugged in but wont boot.
I purchased a faulty iphone 5 from ebay that the seller said was displaying an "error 21" message when connected to itunes. The phone only powers on when connected to a power outlet or pc but only displays the apple logo for a few seconds and then "connect to itunes". When i try to restore and update in dfu mode i get "error 2009" and 1 time in got "error 21". I have connected to power outlet with no battery in the phone and i get the same "connect to itunes" I have replaced the battery and still no luck. From what i can see there are no signs of liquid damage and no damage to cables/connectors inside. Could it by any chance be the dock connector?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Try another battery as I belive you have purchased a faulty one if that does work then you could have a battery connector problem
Esta resposta foi útil?
Pontuação 0
1 comentário:
your right i have fitted a new battery and i now have power but when i try to restore i now get error 3 and once error 16, have you any experience on this? it seems to restore to about 75%.
por
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 3
Duração total: 155
