Ir para o conteúdo principal
Quinta Geração do Iphone. A Reparação deste dispositivo é correta, requer ferramentas especificas e paciência. GSM/CDMA/16, 32 OR 64 GB/Black or White.
2193 Perguntas Visualizar todos
Pergunta encerrada
black screen after wifi chip replacement
hello all,
after i replaced the wifi chip, i have a black screen
replacing the lcd doesnt work
the iphone turns on and i can see it in iTunes.
i can also see the screen doing something it gets light a little bit an the apple logo comes on for like 1 microsecond
then the screen goes black and its off
Esta é uma boa pergunta?
Pontuação 0
1 comentário
finally i can answer,
seems that next to the wifi chip 2 ic are of the motherboard, the fl3 and fl4. saw that on a schematic
how can i find the correct ic to replace them ?
thanks
[image|474030]
por
Adicionar um comentário
2 respostas
Solução escolhida
Wifi chip is difficult to install one I would say you have damaged the board
Esta resposta foi útil?
Pontuação 0
Try taking the chip off again and look if you might have damaged some resistors and capacitors.
Pontuação 0
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 148
