Screen black, but phone is on.
When I turn my phone on the bottom buttons light up but my screen is black. There is an internal crack tat can be seen if the phone is turned a certain way.
Esta é uma boa pergunta?
LCD is damaged and needs replacing.
Esta resposta foi útil?
how much will that be?
Usually, this means your lcd is faulty. You can try opening up the phone and checking the connections for the lcd, but they don't usually come un-done. If you're gonna order the screen yourself, make sure you open the phone up first to make sure it's not the cable and to get used to working on them. Good luck!
As for the price of the replacement lcd, it's about $130 on amazon, last time I chekced.
i have the same problem did you find out what is was?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Duração total: 807
