Ir para o conteúdo principal
The HTC Desire 310 is a dual-SIM Android-based smartphone designed and manufactured by HTC.
10 Perguntas Visualizar todos
Pergunta encerrada
How to replace the motherboard?
Hi,
My son's HTC Desire 310 stopped working..no power, no sign of life. A repair shop said it is the motherboard. How do identify which motherboard to search for? I have found some photo tutorials online that I hope will guide me. Total amateur here, but needs must:)
Paul
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
Hi Paul,
Did they say what was specifically wrong with your motherboard? If you go the route of getting another motherboard, do note that this is the phone itself and you will not retain anything not backed up to the cloud.
When searching for the motherboard, you will most likely find pull-offs that are, of course, used. Check to make sure it is the same model, and also that it is for the same carrier you are using.
Just curious though, what prompted this issue? Was there any physical damage involved?
Esta resposta foi útil?
Pontuação 1
The issue was that the mobile fall in water
Pontuação 1
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 1,333
