Ir para o conteúdo principal
Model A1418 / Late 2013 / 2.7 & 2.9 GHz Core i5 or 3.1 GHz Core i7 Processor
249 Perguntas Visualizar todos
PCIe SSD hold down screw size?
Hi!
I'm planning to add a SSD in PCIe slot on my iMac Late 2013 using your instructions.
Everything seems to be bought, I'm almost ready to start except one thing - I don't know the size of a screw which holds the SSD on mother board and I don't know if it exists (I mean - if it exists while there is no SSD in my config)?
Here's a picture SSD hold down screw
What's the length and diameter of this screw? Can I use a drop of silicone sealant instead of a screw?
Esta é uma boa pergunta?
Pontuação 2
2 comentários
This question was migrated from http://meta.ifixit.com/Answers.
por
Hi dv1977, I have the same iMac and thinking of SSD upgrade. I do have only HDD, would like to add blade SSD.
Would you mind to tell which model have you used ?
Thanks,
Nikolay
por
Adicionar um comentário
2 respostas
Solução escolhida
That appears to be a T5.
Esta resposta foi útil?
Pontuação 1
2 comentários:
This "chosen solution" is not a solution at all. It is actually incorrect. According to these two how to videos, it is a T8 screw, that I am still trying to find myself!
https://eshop.macsales.com/installvideos...
iMac Intel 27" EMC 2639 Blade SSD Replacement
por
You are correct it is showing as a T8 which I have never seen as a blade hold down screw.
por
I think this is the screw for the SSD on the Imac
https://www.ebay.com/itm/SSD-Screw-Torx-...
Pontuação 0
Adicionar a sua resposta
dv1977 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Duração total: 1,058
