Ir para o conteúdo principal
Quinta Geração do Iphone. A Reparação deste dispositivo é correta, requer ferramentas especificas e paciência. GSM/CDMA/16, 32 OR 64 GB/Black or White.
2201 Perguntas Visualizar todos
Pergunta encerrada
iPhone 4s wont charge after screen replacement
Hi guys,
i have a big problem with my coustumers phone.
After the screen replacement the phone could not charge, it shows the charging symbol and looks like its charging, but the battery % dosent get higher.
I have tryed to replace battery and dockconector, and nothing has helped. I have had this problem before, and now i need to know what to do about it :-) ofcourse i have boaght a new phone for the coustumer ;)
Im looking forward to get help from u! Thanks!
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
I'm actually having this same problem. I just replaced the screen and the dock connector and get the red battery and it won't charge. I've taken the thing apart and put it back together plenty of times and still have the same issue. The USB cord charges other phones fine and even charged this phone fine in the past. I even changed the battery and tried both and still nothing works.
por
Adicionar um comentário
2 respostas
How are you sure this problem didn't exist prior to him giving it to you?
Esta resposta foi útil?
Pontuação 0
You can check if the battery connector isn't loose.
Also measure the voltage from the charger.
I think the charging IC causes your problem then.
Pontuação 0
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 292
