How can I check the disk drive?
Is there a way to check if the HDD has failed? I get Fanfare and a flashing question mark.
Esta é uma boa pergunta?
Turned out to be a loose HDD connection.
Esta resposta foi útil?
Start up holding down the Command & R keys: http://support.apple.com/en-us/HT4718
Thank you for the input.
I started a tear-down again and found the HDD connection popped loose when I re-installed the WiFi antenna. There's a tale of caution!
Steen Rancher
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 153
