Bluetooth and Wifi not working
I replaced the bluetooth/wifi antenna on the 4s.
Wifi is still grayed out and bluetooth isn't working.
So I guess the part wasn't the issue.
Any thoughts on where i should look now?
Esta é uma boa pergunta?
Did you replace the IC? Those are soldered on really tough. But it could be other things. Give me more info as to the repair you performed.
Esta resposta foi útil?
You can also reflow the IC first and see if that works. In my case it works 99% of the time.
Just heat up the IC and watch if it worked
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 421
