Ir para o conteúdo principal
Repair guides and troubleshooting information for hair dryers.
Not sure where to place a wire on a variable switch
Hi, I was repairing the power cord on my hair dryer and accidentally disconnected a wire from its variable switch. When I tried to reattach it to what looked like the most logical terminal and I turned it on, it blew up. Now I'm not sure where to put the wire, any suggestions? All advice will be appreciated. Thanks!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
my bet is you shorted out the board, and if so you will need a new board, or frankly a new dryer. You may have inadvertently put a neutral and hot leg together. Anything turn black or smell like plastic burning? Do you have a meter to test for continuity?
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
daxelrad será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 218
