Ir para o conteúdo principal
Repair guides and support for Olympus digital cameras.
231 Perguntas Visualizar todos
Olympus OM-D E-M10 front curtain flutters?
Hi everyone,
I got this problem with my EM 10. When the camera is off, the front shutter curtain stays shut (normally it is open). When I turned the camera on, the curtain will flickers for a few times (make some noise) then it stays shut and the camera will shut itself off.
I can't access the LCD menu and cannot take a picture.
Anyone know how i solve this?
It is similar to this problem on youtube -> https://www.youtube.com/watch?v=dhmzvbxO...
Esta é uma boa pergunta?
Pontuação 3
Adicionar um comentário
1 resposta
Pergunta mais útil
https://www.youtube.com/watch?v=miKYy9vU...
I had this problem after contact with salt water, and was able to fix it by disassembling and washing with alcohol. Check above video for more info.
Esta resposta foi útil?
Pontuação 2
1 comentário:
Did you were able to fix it? I have the same problem. I would appreciate if you can write me to my e-mail: Hernandez.je.4@gmail.com
por
Adicionar a sua resposta
BigRedDog será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 10
Duração total: 1,334
