Ir para o conteúdo principal
Machine-readable instructions that direct computer processors.
Run DLL error in Windows 7?
I get this error:
C;\Users\NewCanaan\AppData\Local\Conduit\BackgroundContainer\BackgroundContainer.dll
What is it?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
3 respostas
Pergunta mais útil
Found this on the web, looks like malware issue.
To resolve this, download AutoRuns and save it to your Desktop.
Create a new folder on your hard drive called AutoRuns (C:\AutoRuns) and extract (unzip) the file there.
Open the folder and double-click on autoruns.exe to launch it.
Vista/Windows 7/8 users right-click and select Run As Administrator.
Please be patient as it scans and populates the entries.
When finished scanning, it will say Ready at the at the bottom and list all entries under the Everything tab.
In the top menu, click File > Find... and type the file name (backgroundcontainer.dll) related to the error message, then click Find Next.
Alternatively, you can scroll through the list and look for any entry related to backgroundcontainer.dll and conduit.
If found, right-click on the entry and choose delete.
Exit Autoruns and reboot your computer when done.
Esta resposta foi útil?
Pontuação 1
Hi, Great info! Could the same work for ... C:PROGRA~1\Common~1\System\SysMenu.dll? The dll system files?
I have Windows 7 and continue to get error RUN DLL--- Page unresponsive? The Specified Module could not be found: Have tried... "taskschd.msc.... CMD--- "SFCC/SCANNOW--- does not work.
Part of the problem is certain videos do not open after clicking link. For example opening a video link for an information topic..i,e real estate investing?
Pontuação 0
1. You have to operate as an administrator, regardless of the steps you are going to do with regards to Laptop or computer.
2. The particular techniques we have discussed earlier are often precisely the same for each and every Windows type, with small differences.
Pontuação 0
Adicionar a sua resposta
smburke62 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Ao todo: 289
